David Gaudreau
David Gaudreau
Might be a dumb question but how will I know how much power this amp will make with my speaker setup? Specs on amp say 150 watts per channel @ 8 Ohms and 200 Watts per channel @ 4 Ohms. Per Chet, from Deft tech he said set the amp in 4 ohm mode as the speakers are 4-8 ohm. So how do I do this? Or will the amp already know what power to make by just hooking up the speakers.
Warpdrv
Warpdrv
Agreed... most amps will be nominal in the 8ohm range, and if called upon will provide the load required to hit that 6 or 4 ohm load.. so its just plug and play for you... :)
David Gaudreau
David Gaudreau
sweet!!! Cant wait to hear all my new gear!! in my new room!!
