enob said:
Looking to upgrade my 2 Front Speakers with in the next 6 months and from I have been reading Electrostatic speakers have been perfected and widely available via various makers. I am looking to possibly purchasing a pair of Martin Logan's but before I go out to listen to them I wanted to get some opinions on them. Do they really sound that much better than standard speakers are they going to still be around in years? I did a search and did not come up with any other threads on this.
Anyone have an experience or insight?
I love Martin Logan's. My first experience with Martin Logan's was with the CLS model back in 1987 being powered with this little itty bitty 50wpc Amber Amp...... a moving, almost mystical experience. Martin Logan was not a new company then, and I doubt they are heading down the sewer... there are just too many ML lovers out there. By the way Amber is still around as well (there 7 channel amp is $3800 and is rated for 70wpc - they still don't make big amps, but then why bother, when they make such good amps).
Reference power requirements & room acoutics. Electrostatics, when properly amplified, and NO that does not mean a huge amp, rather the proper amp.... a well controlled amp with a beefy power supply and ample dynamic reserves.... properly positioned in the a large enough room can be the most revealing speakers that you will ever hear. Stuff those speakers in a dinky room the size of my home theater, or try to overpower the speakers with one of those big, cheap, megawatts of power amps, and you will absolutely hate the speakers.
You most likely won't find a lot of threads about ML on this board, or many other boards, as the speakers are not exactly mainstream for the typical home theater user. Not to mention, a good ML setup of speakers for home theater will cost more than my entire home theater.
If you can afford them, got the room for them, and have the amp to handle them, by all means buy the Martin Logan's.... your ears will love you.
By the way WAF is not a problem, just tell her it is either the speakers or her. Wives are replaceable, great speakers are hard to find.
