Hey everyone,
I picked up a set of electrostatic speakers, and I seem to have problems powering them..... I have tested on two receivers Teac AD-G9320 and a Pionneer VSX-14. Both receivers push 100w per channel, while the pionneer sounds much better I have to crank that sucker pretty high to get good sound.... Not optimal.. but loud enough for movies.....
I haven't played with electrostatic speakers before, but this system was pretty loud when I tested it at the CES show. I wanted to know if this is an issue about power coming from the receiver. Here is some information about the speakers.
Speakers:
- Frequency response : 280 Hz ~ 24 KHz
- Sensitivity : Equivalent to 86 db / 1 W / 1m ; measured at 4 meters
- Impedance : Normal 6 ohm
- Audio power ( min / max ) : 20 / 80 Watts ( music )
Sub:
- Maximum power output : 120 Watts
- Input impedance : 47 K ohm
- Frequency response : 30 Hz ~ 280 Hz
- Component : 204 mm ( 8 inches ) dynamic woofer
- Crossover : 220 Hz ~ 280 Hz ( Adjustable )
- Middle frequency fine tune
- Built in speakers protect circuit
The system was tested on a Denon 3805 and it was not turned up very loud at all... compared to what I am doing right now. I know the Denon supports 6ohm at 160w per channel... Could this be the factor for my soft sounding speakers? I was also told that electrostatic speakers require alot of power to push them... is this true?
I was Planning to buy a Yamaha 4600, but wanted to know if I should stick with Denon instead... or at least have a better understanding of why my speakers sound so soft with these two receivers.
Any help would be great!
Thank You
