I am not referring to any audio components, but the Zard racing pipes I put on my 2021 Royal Enfield Interceptor 650. I just love the sound. It’s not even loud. They have DB killers which I have no interest in taking out.
I put on a great footpeg/shift lever and brake lever kit this past weekend. The pegs are adjustable 40 mm, 360 degrees. I am 6 ft, so I wanted them at the lowest position. The shift lever adjusted fine, but the brake lever was at it’s lowest possible position and I needed another 1/2" to 3/4". I fixed that by fabricating a plate to lower the pins or pegs, whatever you want to call the end. Worked out just exactly as I envisioned!
The photo shows before and after fabrication.
