I understand the dynamic vs. continuous debate. I have a problem with companies saying 100 watts x 7 and claiming it is a 700 watt receiver when they used a two channel FTC method for the numbers. You know and I know that that receiver would not be able to deliver 700 watts all at once. If it cannot do it it sould not be stated. Receivers using the FTC two channel method should not be able to state their power x 7. it should be stated as: Seven channel receiver capable of no greater than the sum of the FTC 2 channel power at any given time.
Here would be an example:
XYZ 7 channel receiver
120 watts x 2 FTC power two channels driven simultaneously
35 watts x 7 all channels driven simultaneously
There is no bs here, it is plain as day, this is what you are paying for. the companies that choose to rate more conservatively would benefit from this I suppose.
It is misleading when it is stated like this:
120 watts x 2 front L/R
120 watts center
120 watts x 2 rear L/R
120 watts x 2 surround back L/R
If it is going to be listed that way then it should look like this:
120 watts x 2 front L/R (if they are the only channels running)
120 watts center (if it is the only channel runnning)
120 watts x 2 rear L/R (if they are the only channels running)
120 watts x 2 surround back L/R (if they are the only channels running)
Even if all channels are not running all out, one would still not get the power they claim. Here is an example. Say there is a large explosion or action in the front left partial right and center that lasts for 5 seconds. The volume is at reference level and the front left partial right and center speakers would require (we will use the 240 watt amp from above 120 ftc x 2) 100% of the power the receiver has for the explosion (80% for the center and left, 96 watts each and 20% for the right 48 watts). Now let us say that the explosion or action sets off another one that lasts for seven seconds (it is now supposed to be louder)but now is asking for 80% power across the front three speakers (64 watts each)and requires 20% of that 240 watts for the rear and surround back channels (12 watts each) for falling debris. Because the receiver does not have the capability to run all the channels simultaneously to the same power high power level ther has been a reduction in dynamic range from the original explosion about -1.5 db in the front.
Now let us say the same scenario exists with a receiver designed to do 75 watts continuous all 7 channels driven simultaneously. For the first explosion the left and center would receive 75 watts a channel and the left probably about 45 watts. With the second explosion the front three would STILL RECEIVE THE SAME AMOUNT OF POWER and more than the first explosion or action with no loss in dynamics. The rear channels would receive roughly 15 watts each. While there is not much audible difference in the second scenario between receivers, there would be a negative difference between the first an second scenarios with the first receiver. And a positive one with the second receiver.
The second action sequence is supposed to sound bigger and more dynamic (which it does on receiver 2) but on the first FTC derrived receiver it stays about the same overall volume.
Sorry for the long post guys.
