U
Unregistered
Guest
I am new here and have to say this is a great source for information, Thanks AudioHolics!!
With that out of the way I was wondering if anyone could help me out with a question.
I am in the market for a new Home Theater Receiver but would like to find one with DVI output so I only have to run the one cable to my Plasma from the receiver and have less junk in the wall. I think I only have seen one Receivers with this and it was ultra high end.
Does anyone have any insight when this feature will become more mainstream on receivers in the 1-2k range? I contacted Yamaha and got the official we don't comment on future hardware.
Thanks in advance..
Tsunamii
hopjohn
possible solution
You might not be able to find a receiver in that price range that will support DVI switching, but you can use an external switcher for it to use in conjunction with the receiver of your liking. I believe they sell them at
www.digitalconnection.com
av_phile
If you only use one DVD player that has DVI outs, use this to connect to the DVI input of your plasma. Otheriwse, you may have to invest on a video selector box with DVI terminals. I believe newer receivers will sport this facility very soon, not just in their flagship models. Right now I still have to see a receiver with multiple analog 5.1 sources so I can switch between a dedicated DVD-A player and a dedicated SACD player - both requiring analog 5.1 inputs.
U
Unregistered
Guest
Thanks
Thanks for the reply's!! I guess Ill wait to see what comes out next year before I change out any equipment. I do hope that Yamaha comes out with one next year. Thanks again..
Cheers... Tsunamii
