Purchasing a new Plasma tv and am a bit confused about the DVI connection. The specs for the unit, LG DU-42PX12XC, state that it has a a DVI with HDMi connection. I understand these are two totally different connections? (yes, they use a small i, does that mean anything?)
Is there such a thing as a cable that goes from DVI to HDMi and vice versa or do I need a DVD player with the same type of output connection?
The tv does not arrive for a few weeks and I'd like to get the wiring in before hand.
Also, is there a CL3 DVI wire? need to run about 25 feet through a wall to get to the dvd location.
Thanks in advance,
Rob
