DVI/HDMI vs. Component?
rusty1285
I currently own a SONY V2500 46'' BRAVIA and I'm using component cables at the moment to connect it to my moto cable box from Charter Comm.
Would my picture improve at all if I used a DVI/HDMI cable to connect my cable box to my SONY?
by the way, has anyone ever run into compatibility issues with this sort of half DVI/HDMI type cable?
markw
rusty1285 said:
Would my picture improve at all if I used a DVI/HDMI cable (instead of component cables) to connect my cable box to my SONY?
Not as much as all the hype would lead you to believe. You may not even notice a difference.
DVI and HDMI in terms of video are identical, so there should be no issue. That is what I use for my PS3 right now and it works great. There is already a thread on this that should more or less answer your question, but basically for the same resolutions, there isn't a huge difference.
JeffCos
I have run into a problem. When I plugged my DVI-HDMI cable from my SA4200HD to my olevia 232v, all the colors were negative (reversed).
