DVI Cable Recommendation from Best Buy
brownkc
I have a gift certificate to Best Buy that I need to use and thought I could go ahead and pick up a DVI cable. I am planning on buying a 50" Sony SXRD RP this spring. I know that HDMI is preferable but my signal will come from a Time Warner HD DVR box. I checked the current one they use and it has DVI connections, no HDMI.
I would like to get a 6'+ cable (I have had a few stretches with recent cables). I like quality but also pay attention to a diminishing return. If a $100 cable gives a great picture in all but certain situations and the next step up is $200, I will probably stick with the $100 cable. The TV is primarily used for watching comedy/action DVDs, DVR TV shows and football.
Your help is appreciated.
edwelly
edwelly
my $0.02
I would get something else with your gift certificagte, like a movie or cd. I would buy the DVI cable from www.partexpress.com - they have great cables and even better prices. Good luck...
