DVI and component connection with SAT & DLP
machineman
I bought a new Samsung DLP HD TV and a Samsung HD Direct TV box. Connected everything via component video through my Pioneer receiver and had a excellent picture.
People were telling me the best picture quality for HD is through DVI. So I went and bought a high dollar DVI cable and connected it direct from the SATV to the TV. My picture quality was really bad. I tried several different settings on the SATV box but SATV HD, HD over the air, everything was no where as good as the component video. I had several different people look at it and they all agreed that all picture quality was better through the component video.
My question is why????? :confused:
Any help would be appreciated.
Rex
Rex
I had almost the same problem with my cable co. Did you go into the menu and select the proper source for DVI. Maybe you still had it going through your component video source. The cable guys arent much help most of the time with these types of problems.
Seismo
Did you get the proper DVI cable for your DLP?. There are a few types.....I don't know about Samsung, but for my Toshiba I use DVI-D.
Seismo
machineman
Thanks, I didn't know there are special cables. I only saw the one type. Nowhere in the Samsung manual is this mentioned. :confused:
Rex
Rex
Yeah, my samsung has the DVI-D cable. The bad thing about DVI interface is it can only handle video signals and not multichannel audio like HDMI can.
Rex
Rex
Seismo
A DVI-I cable will not plug into a DVI-D plug.
