Hello Arvee
Simple test
You have the cheap yellow composite cable that came with the player.
Use that cable as a test cable by disconnecting each component cable and replace it with the yellow composite cable starting with the green. Look at displayed image between each swap.
This will tell you if you have a faulty cable creating a sync issue between the DVD player and the display device with no cost out of your pocket.
You don’t indicate if the DVD player you are using is set for progressive or interlaced output. If it is progressive make sure that the component input you are using supports a progressive signal as some older display devices had separate inputs that supported interlaced only component connections and another set for progressive.
Report back here with your evaluation for further assistance
Hope this helps
Ray
