Francious70
Francious70
I'm currently looking into getting a new DVD player and a new TV. My question is which one to get first. I'm also working on a budget of $500 max for each. And also I need a few suggestions. This is what I'm looking for:
TV
20" or greater
DVI or component input(s)
Preferably flat screen
Pregressive scan (does this even matter for a TV??)
HDTV
16:9
DVD
DVI or component output
Coax and/or optical output
Progressive scan
All suggestions are welcome, and if I need to revise my chriteria, I can.
Paul
Francious70
Francious70
Buler, Buler?? Anyone, Anyone?? Fry, Fry??
Paul
gregz
gregz
Francious70, get the DVD first. That technology is mature and prices have dropped about as far as they're going to. TV's on the other hand, are going through a transformation from low-resolution tube to flat screen high definition, and prices are still on the steep part of the down curve. Net result: putting off your TV purchase means you'll likely get a bigger TV for the same price later.
Francious70
Francious70
Would an X-Box be an acceptable choice for a DVD player?? They offer 720p and 1080i at 16x9 with 5.1 and a HD pack.
Paul
Z
ZEK
Francious70
the XBOX does a decent job of playing dvd's,but it only outputs 480i in
the movie mode
my opinion being your TV will be the main attraction-center piece-of your
home theater and more than likely the unit you will keep the longest.
Based on that therory,I would suggest you take the $500 from each and apply
it towards a nice TV of your liking.
you can buy a dvd player that does a good job for very cheap now a days
one of the 'upscaler' (720,1080) output players are interesting
and the future holds "HD-DVD" players also
just my thoughts :)
