Philips DVP3140 follow-up
This is a follow-up to my earlier posts. Adam, thanks for the tip on the Philips DVP3140.
I did end up purchasing a Philips DVP3140. I used the hack to unlock the player and make region-free. So, I then checked it out on a couple of the Chinese PAL DVD-9 discs and it seems to work just fine. I also used it to play CD music discs with very good results. The remote is compact, a little too compact in my opinion. The number keys in particular seem to be too small. The on unit display is rudimentary, but at least if has a display unlike the Coby DVD-224 that it replaced.
I had thought about buying another Coby player, however, since the warranty on the Coby is only 90 days compared to the Philips one year warranty, I decided to pay a little extra and get the Philips. In addition, the Coby DVD-224 has rather poor customer reviews on the Amazon.com website. The main problem seems to be reliability. In defense of the Coby, the one we owned lasted just a little over two years. Not too bad considering it only cost $19.00 plus tax.
Bottom line, the inexpensive ($39.95 at Circuit City) Philips DVP3140 will play Chinese DVD and CDV discs once the all region code is enabled. I hope that this post will be useful to someone else looking for an affordable all region player.
