Rob Babcock said:
Yeah, it upsampling doesn't create data. If you don't understand what it does does do there is a primer here on this site.
I suggest you read it, then. Increasing the frequency of a pre-existing sample frequency does not/can not add information.
I take it then, that you listen to MP3 then, WmAx?
How does this have any relevance? I have not claimed to hear anything in this conversation.
That same tired BS about DBT has been spouted about CD vs MP3, too, but anyone with decent equipment call tell that ain't so.
Sorry, but this conversation is not about MP3.
I'm not aware that you'd need DBT to tell black from white or hot from cold, but that's how obviously superior DVD-A & SACD are.
Did you even read my prior posts? Seems not. You realize, that so far upon analyis of a SCAD or DVDA vs. RBCD, that it is evident that not even the same masters used to produce the different versions, right? You are really cmoparing apples to pears in that case. In one example, the recording engineer from Telarc admitted when asked via email, that a RBCD version of a specific recording was not the same as a SACD version(Tierney Sutton, Dancing In The Dark) when I enquired about certain sound quality issues with the RBCD version.
While we're on the subject of DBTs, please link me to the studies that show 44.1/16 is equal to higher rates or DSD.
Bandwidth and signal:noise ratio perceptual studies:
Which Bandwidth Is Necessary for Optimal SoundTransmission?
Plenge, H. Jakubowski, P. Schone
Journal of The Audio Engineering Society, 1980, March, Volume 28,Number 3
Perceptual Discrimination between Musical Sounds with and without Very High Frequency Components
Nishiguchi, Toshiyuki; Iwaki, Masakazu; Hamasaki, Kimio; Ando, Akio
AES Preprint Number: 5876 Convention: 115 (September 2003)
Signal-to-Noise Ratio Requirement for Digital Transmission Systems
Spikofski, Gerhard
AES Preprint Number: 2196 Convention: 77 (February 1985)
-Chris
