Reorx
Where is a good place online to buy DVD-audio?
Will a new format be coming out with the release of Blue-Ray and HDDVD? Replacing DVD-A and SACD?
Reorx
JVC
JVC
One place is: http://www.telarc.com
Telarc is known for extra good quality recordings.
Here is another site with a selection of dvd-a music:
http://www.buy.com/retail/searchresults.asp?search_store=6&querytype=music&qu=dvd+audio&loc=109&dclksa=1=111&dclksa=1
Good luck!
Edit........
Oh yeah, in answer to your second question............ The new Dual Discs (cd on one side/dvd on other), are what they expect to take the place of sacd and dvd-a music. They've had a lot of problems, using these discs, in some players. I think it's mostly because they are thicker than normal discs.
mitch57
Also try www.towerrecords.com. They have some of the best prices and free shipping with some orders. To search for just DVD Audio disks type "DVD Audio" in their search engine.
Dan Driscoll
www.elusivedisc.com
There may be a new audio format for music, but not for a while. I'm thinking that DVD-Audio might be an ideal format for HD-DVD and Blu-Ray. It's designed for multi-channel from the ground up and it's lossless. There's no reason why DVD-Audio can't be used for HT audio, as well as music.
jaxvon
jaxvon
Dan Driscoll said:
www.elusivedisc.com
DTS-HD is a new format coming out for movies that is bit-for-bit identical to the master soundtrack, even all the way up to a 192kHz sampling rate.
Dan Driscoll
What's the difference between DTS-HD and DVD-Audio?
They are essentially the same thing (or at least very similar).
