dual or single subwoofer?
clouso
ok guys i need your opinion...if some of you can go look on paradigm website and tell me?....would it be better dual seismic12 or a single sub15 pls..thx!...my room is about 20' by 12'..open area on living room and kitchen.
For the price, I wouldn't be looking at Paradigm for a sub unless you are buying their top teir subs like the Sub25. What is your price range?
clouso
i can go up to 3000$...now i know i might get dual 13ultra's for 3000$..but they are just too huge..thats why i got my self a seismics12!
I'd start with a single Ultra if that is what you are thinking. It can handle a pretty large area. One of the guys here has a fairly open floorplan and it still absolutely pounds you and still sounds clean.
Since they don't have the Servo15 anymore, I would say go with dual Seismics instead of stepping up to the 15 since it is technically a lower model and only shows a -3dB rating of 35Hz, vs the 17Hz of the Seismic.
lsiberian
lsiberian
A submerssive is an incredible sub. Go that way.
Chopin_Guy
Chopin_Guy
Another vote for Seaton if size is indeed an issue and you cannot fit two Ultra 13s in your space....$3k can buy you alot of sub. In that price bracket I would say you could look into a Danely Sound Labs DTS-20 but that thing is huge....
Warpdrv
Warpdrv
Yes the Submersive can be delivered to Canada, and Mark is a great guy to work with...
That is a very very good choice in a subwoofer....
And Now they come in pretty colors as well.... I also believe he is now using magnetic grills too....
I believe there are some other colors coming out as well, but here are a couple
Cherry
Black Oak
clouso
thx warpdrv...it is a dual 15'' drivers right?...and what would be the canadian price?
