The Submersive is a terrific sub, from what I have read, but it isn't necessarily the best performer, although it certainly is one of the best in it's price range. The A7 900 would definitely best it in output, and it's supposed to have excellent sound quality too. It's caveat is, do you have a place for something so large and the ability to move around the 400 lbs behemoth? How would the Submersive stack up against a pair of HSU ULS 15s or Rythmik F15s? It is not the best without qualifications, as with any of those subwoofers; they all have a slightly different role.
As for the HK3850, I'm not certain about that receiver, but the newer version of it does not have bass management, so I doubt that it would either. What does this mean? Yes, you can use the subwoofer's crossover, but the speakers are still going to try to play the full range too, as opposed to being cutoff by the receiver. This is not an ideal situation if you are an audiophile bent on the purest sound, but it really hasn't bothered me much, although I would prefer not pushing my mains to try that kind of heavy lifting at those frequencies. It is probably not going to be a big deal to you, and I don't think you would notice unless you were really listening for it. All this depends very much on what speaker you are using, of course.
Either way, can your speakers keep up with the massive subs you are planning on adding to your setup? You will need some serious speakers to not get overwhelmed by something like two Trinitys. By the way, if you are really going for that massive, deep pipe organ effect, the A7 could certainly do that better for cheaper, if you can accommodate its massive size. You might also call or email Mark Seaton and inquire about his Terraform design.
By the way, you might also consider tying your subs to the left and right channels instead of the subwoofer outs. This may make more sense if you are going to have two subs, and if you are going to place each sub next to a speaker.
One more thing- if I were you, I would take a close look on how you intend to power two large subs, electrically speaking. Two or more large subwoofers may be too much for the electrical circuit they are on, especially if it's only 15 amps. I wouldn't put any of these on the same circuit unless it was 30 amps.
