How loud do you like it? If you really want to blast the bass, get the 15"s. If you are OK with loud but aren't going to push the system really hard, stick with the 12"s. Yes, the 15"s would play cleaner than the 12"s for the same SPL, but you aren't likely to notice until high volumes where the 12"s get stressed. I would say the 15"s are worth the extra expenditure since they pretty much double the midbass of the 12"s while only being about 50% more expensive.
