Congratulations on the major upgrade. Those are all good questions and usually result in very long threads, but I'll give you the quick abridged version to get things started.
lbcheng said:
1. What are the differences between the different modes: Dolby Digital, Dolby Digital EX, Dolby DTS 5.1, 6.1 DTS-ES Discrete, DTS-ES Matrix, Dolby Pro Logic II, Dolby Pro Logic IIx, DTS Neo:6, Cinema 6.1/5.1, and Music 6.1/5.1), and finally, HK's own Logic 7 (Cinema, Music, and Enhance).
There is a single sheet describing each of these permutations, but what I'm really looking for is your own subjective descriptions of what are the top few for music and top few for HT to test out on my own ears. I am running 5 speakers plus sub.
- Dolby Digital and DTS are lossy compression formats and are the formats found on DVD. They are 'discrete' formats - meaning each channel is separate and distinct from the others. Dolby Digital EX is a 6.1 format, but the 6th channel is not discrete (it is matrixed into the surround channels and extracted during decoding). DTS-ES Discrete and Matrix are also 6.1 formats, with the discrete flavor being discrete and the matrix version being matrixed like DD-EX.
- ProLogic IIx and DTS:Neo6 are 'matrix decoders'. They work on 2 channel analog or digital sources and turn it into 5.1 or more channels. You could use PLIIx to turn analog signals into 5.1, 6.1, or 7.1. PLIIx will also turn DD 2.0 or DD 5.1 into 6.1 or 7.1. Neo:6 only works on 2 channel analog or DTS signals.
- Cinema and Logic7 are also matrix decoders. Logic7 is HK/Lexicon's proprietary matrix decoder.
Which to choose? It's all personal preference. If the disc has DD or DTS, usually you just want to use the native decoder for that format, but you can use one of the matrix decoders if you want to output more channels than are present on the disc; ie use PLIIx to turn DD 5.1 into 7.1.
lbcheng said:
2. Is there any advantage to running my single video input (DVD) through the receiver instead of directly to my TV? The DVD has component outs but the TV does not (only S-Video), so I assumed that I should keep the direct DVD-TV hookup.
The advantage of running everything through the receiver is ease of switching. The receiver will switch audio and video at the same time so you don't have to switch inputs on the tv as well. If the tv does not have component video inputs then you have no choice but to use the direct connection from dvd to tv if you want to use component video.
lbcheng said:
3. Is there any advantage to using the 48khz to 96khz upsampling setting? According to the manual, "the AVR635 allows you to upsample the incoming 48khz signals to 96khz for added resolution." I didn't hear a difference, but wasn't sure if I was either in the wrong decoding mode or need special audio material.
Generally there will be no difference, especially since 96 kHz is not a direct multiple of 48 kHz. Upsampling is 'interpolation'; ie the processor adds additional samples to increase the sampling rate. Search the forums for 'nyquist' for a detailed explanation.
4. Any reason to set up my rears as "Small" speakers vs. "Large"? I think that setting them as Large will push more of the frequency to them, but am not sure if that is a good thing for HT.
Yes. Unless the surround speakers are truly full range (can go as low as 20 Hz) you want them set to Small so that the receiver sends the bass to the subwoofer and not those speakers. All speakers Small, Sub=Yes, and an appropriate xover frequency (start at 80 Hz and tweak from there) is the best overall setting. Search for 'bass management'.
lbcheng said:
5. My audio is currently coming in from a CD jukebox through RCA stereo plugs. The unit does not have an optical/digital out -- would there be significant enough improvement to justify looking for a new unit just to get the digital out?
You will be getting a 2 channel analog signal to the receiver and could use one of the matrix decoders to turn it into 5.1 or greater. If you were to buy a CD player with digital outs, the receiver would then get a 2 channel PCM (digital) signal and will do the digital to analog conversion. If the receiver has better DACS than the player (usually the case) then a digital connection would be preferred.
lbcheng said:
6. Interconnects: The HK manual recommends 16 gauge or lower on everything. I am running 18 gauge about 15-20' to the surrounds and don't think I'm likely to change those. I would like to hear whether recommendations on whether I need 14, or if 16 or 18 is okay for the mains and center (all 5' or less). Does brand matter for the same gauge? (My wife bought a big roll of 20gauge Monster cable that I don't know what to do with now)
The only thing that really matters for speaker wire is that you use the correct gauge for the length of the run. At 15-20', 18 gauge would be ok, but 16 or lower will reduce the losses a bit. rogerrussell.com (ex McIntosh engineer) has a nice table with gauge recommendations based on length.
Whether you will really be able to hear a difference between 18 and 16 gauge at such a short length is debatable, but for peace of mind, I would opt for 16 or 14 - anything lower than that is pure overkill.
lbcheng said:
7. Last: I'm not a big gamer, but wonder if there is anything that will allow me to play a game on my laptop in the living room with audio coming through the new setup. A wireless solution is what I'm looking for, as opposed to 10' RCA cables splitting off of my headphone jack.
There are many devices available that connect to both your home network and stereo (Squeezebox2 is the best, IMO) and many of them do 802.11 b/g wireless. If you don't have a home network, but the laptop has a wireless card, you may be able to set it up in 'ad-hoc' mode and connect directly to the media streaming device.
Thanks in advance for any thoughts -- I would have procrastinated forever had I not found this board and been encouraged by your advice.[/QUOTE]
