DSP A1000 audio output to WiFi transmitter
K
Karawaci
Hi,
I need some assistance from you experts! I have the old DSP A1000 that I am using simply to receive input from my turntable and hopefully then send that analog signal via an RCA to 3.5mm jack plugging into a WiFi transmitter. My issue is that I cannot figure out if this amp can actually do this. Can anyone help with what that cable configuration might look like? or is this not gonna happen? When i tried using the main out lines with the rca end of the cable, no sound is being transmitted.
thanks in advance
Hi,
thanks in advance
That unit is analog. So if your Wi-Fi transmitter has no DAC this is not possible. So the rec outs need converting to digital either by the transmitter or a DAC between the two.
K
Karawaci
Thanks TLS Guy! Just to clarify, I assume you mean an Audio to Digital converter or ADC rather than a DAC? same thing but in the opposite direction right?
Yes, you will need to convert the analog to digital and on the other end digital to analog.
