You should probably call Infinity for replacement parts. This drivers shouldn't be more then $20 each.
As to worthwhileness of this operation, is really up to you. If you like the speakers and you are on the tight budget, replace the drivers. If you aren't on the budget and looking to upgrade anyway, then perhaps it is time.
