N
nm2285
A few questions regarding a large, 2-way bookshelf design:
1) When offsetting the two drivers from a vertical alignment in a bookshelf speaker, is there any standard or best practice method of determining the amount of offset?
2)What are the advantages of inverting the woofer and tweeter? When should this be done
3) Is there any method for determining the optimal vertical distance between the woofer and tweeter? I have a tall front baffle and am not sure how far apart to place them.
As a note, I'm using the Vifa XT19 and the Peerless 850122.
Thanks for the assistance!
WmAx
WmAx
The offset is used[when it's used] to create an assymetrical re-radiation diffraction behaviour. By using an assymetrical format, for example, you spread the affected frequencies into two lower amplitude bands, as opposed to a single higher amplitude band, thus spreading/distributing the effects. Here is a very good article on the subject:
http://www.birotechnology.com/articles/stuck.html
It depends on the crossover topology used. If you have a 2nd order L-R crossover, for example, the phase angle at Fc[crossover points] will be 180 degrees out of rotation between the two drivers. This will result in null[opposite phase cancels in phase]. You must reverse the polarity[reversing the relative phase at Fc] of the tweeter in order to prevent the null. In a 4th order L-R, for example, no polarity inversion is required, since the phase angle will of each driver will rotate an opposite 360 degrees[completing a full circle and being in-phase as a result] from each other at Fc. Just remember, that generally speaking, every order[6db/octave] equals a 90 degrees relative phase shift.
Yes. Make it as close as possible. The further distance, once 1/2 the Fc frequency wavelength[in air] is exceeded[actually, this assumes an infinite slope rate, which is not feasible, so in reality even less than 1/2 is ideal due to overlapping frequencies past Fc], measuring from one driver center to the other driver center, will result in worse vertical response linearity. So, simply, make them as close as possible to ensure the best performance.
-Chris
N
nm2285
So is there a good way of determining how far offset the tweeter should be from vertical without lots of software?
