bmccord
bmccord
Hey all, I am workin on yet another design. Basically a pretty looking end table paneled with Trespa and 1 3/4" Aluminum angle to trim the edges. Anyway, it is still a down firing unit but i was also considering making it down ported as well. The unit has a footprint of 26" x 30" and sits up on 2" diameter brushed aluminum legs that are 3" tall. I figure that if there is any port noise, the carpet may help mute it... Anyways, what do you think? Down firing ports a good idea or not. They would be 4" in dia (and 17" long). I am almost done with shop drawings and I will post them when I finish them. The box would have a gross volume of 8.48 cu. ft. which would be pretty tasty with 2 dayton 12" HF's:D
Brett
bmccord
bmccord
OK, this is what I have so far. It's not too detailed but not bad for 15 minutes:p
What do you all think?
bobgpsr
I thought that ports should be at least the distance of their diameter from a flat surface. So you should stand it up 4" rather than 3".
I think you would do better to post this in one of the DIY speaker areas like in HTGuide or diyAudio to get more responses.
Bob
bmccord
bmccord
OOPS, you know, I completely forgot there even was a DIY section. Sorry about that...
Brett
L
ltworf13
WOW! I love it. I would love to know how to make my own speakers. Great Job
pikers
pikers
bmccord said:
jeesh, not one responce. Where you all hiding:p
We're all waiting for you to realize the problem with your speakers isn't your subwoofer.:eek:
