Im using the Onkyo TX-NR808. So lets say you set your mains to "Large/Full Range", the receiver then allows you to set Double Bass to "On or Off". My question is, if you were to select "Double Bass: On", then what frequencies are sent to the sub?
The only subwoofer crossover option in the menu refers to the LFE channel, and this only applies when using sources such as 5.1/6.1/7.1 etc. Changing the value from the 120Hz default has no effect.
I've sent Onkyo two emails asking about this, but that was over 3 weeks ago and still haven't heard anything back.
