Unless you are building a custom house however, you are going to almost certainly be stuck with an open floor plan type home where, at least on the main floor, the kitchen, living room, and entry way all flow together with openings into each. Almost unavoidable. I'm no good with room treatments-but instead of just telling him it's bad, lets be a little more constructive and tell him how to make the best of a bad situation. Thought's on ways to minimize the effects of open rooms?
My only suggestion, and not a good one most likely
is to get a "size up" on your sub than you would normally go with if you have a big open room in order to fill it with bass (if that's even what you like to do-some people don't care for that much bass).
