does yamaha 2500 have video selector
superblaster
any one knows if yamaha 2500 can monitor different video other than the audio source, I know Denon has this feature, I am considering buying a yamaha, just want to know if yamaha has this feature too. thank you
MarkH
MarkH
Not fully sure what you mean, but the Yammie has a Zone 2 video output (choice of composite & svideo) as well as a powered Zone 2 audio output.
krzywica
krzywica
If you mean can you watch tv (video source) and listen to a cd (audio source) at the same time, in the same room, then the answer is yes.
superblaster
I have 2 dvd players connected to the receiver, sometimes I want to use a DVD as a video source, and listen to a cd using another DVD player at the same time in the same room, if yahama can do that, can you tell me how? I looked at the machine and manual and I didnt see any video selection switch. thank you
krzywica
krzywica
No I don't believe it can do that. There must be an A/V input and an Audio only input for this to work.
Mega2000
You can manually set up one of the other inputs to used one video source and a different audio source. I haven't tried it but it seemed like there were options for that in the GUI
like, you can set the DTV selector to use composite input #1 and audio source #3
