Does thus exist, whats it called, and Which is best?
Z
Zeedre
Hi audiophiles,
Here's what I'm thinking must exist. (I've poked around and searched but not found exactly)
I'd like to connect either my smartphone or directly to maybe pandora or Internet radio sources to a pair of very unobtrusive yet very good sounding speakers. my friends have those docks that never sound good to me. So to some extent maybe that on steroids?
No tv in the room. It doesn't have to be very loud but this living room is 11x20. Im thinking I should have a bit of distance between the two speakers? Hopefully less than 200$
All ears to your knowledge.
Z
Actran
AirPlay is apple's technology that will allow for that. I'm not sure what / if google, android, or windows phones use. If you have an apple phone, just buy a receiver or dock that supports AirPlay.
i use a denon 2312 with AirPlay for the same reason.
Hobbit
Just google "internet radio." I have a grace digital wifi tuner and it streams pandora, aupeo, lastfm, and many more and all the internet radio stations (which nowadays includes all the local stations), it also streams all my music that I have on my computer. The sound quality is great too. Then you can download an AP that allows your smartphone to act as the remote for it if you please. Many of the new AVR's have similar features. Albeit, most I've seen don't have the functionality as my GD.
BoredSysAdmin
BoredSysAdmin
Hi audiophiles,
Z
Question - when you say directly connect the smartphone to speakers - do you mean wirelessly or by wire?
If it's prior -> see below J_Garcia suggestion for A2 speakers,but if it's wireless system is what you looking for - it probably doesn't exist in your price range
Z
Zeedre
Ahh, powered speakers. Ok. got it. Researching. Thanks for the help!
