I have plugged red and white RCA audio calbles into the speaker bar and plugged the 3.5 mm end into my ipod and it sounded great. I didn't have to switch a source as the TV was not on since the ipod was directly plugged into the speaker bar. I was just wondering if there is a way I can have the TV AND ipod plugged into the speaker bar at the same time without always having to unplug one to use the other.
This might seem like overkill but it will do what you want, which is to switch between audio sources, and more. It'll even handle component video which may come in handy later. I bought one of these at Walmart.
Simply plug th red/white ananog RCA jacks from your sources (Ipod, TV, whatever) into the input of this box and the box's output into the single input in the sound bar. Then, simply press whatever button summons the source you desire.
There's quite a selection of these devices on Amazon. For a page of similar items, click
here.
Remember, all you really need is the red/white audio selection. Everything else is simply icing on the cake, but it doesn't hurt to have it.
