does ny 1 know about onkyo amps???
K
kerjaiben
Hi all
Just wondering i do not know anything about stereo stuff but i just bought a onkyo amp not sure what one but its older i hooked it up to my speakers and it stopped working then took it to the shop to get fixed and the guy said there was nothing wrong with it i then brought it home again and hooked it up once more only to find it is still doing the same thing. my speakers have been previously hooked up to a sony stereo and working fine i cant work out why it is doing this they guy at the shop said something about a memory or my speakers are faulty but they work great on the other system can anyone help me please!!!!!
thank you :confused:
Nomo
Nomo
OK. First of all, breathe. The model number should be on the front of the amp or receiver.
What is it doing or not doing? Does it power on?
Buckeyefan 1
Buckeyefan 1
Take some pics and post them so we can see how you are hooking up the amp (use photobucket.com img files). Also, a list of which receiver and amp you have would be helpful. (I'm assuming you are using an amp and receiver, and not calling a receiver an amp)
K
kerjaiben
hello ok the model number is TX DS484 Getting some sound but very quiet It could very well be my speakers but I cannot understand why they work on the old system
Buckeyefan 1
Buckeyefan 1
That's a receiver. You must not be from the States.
http://www.hometheatermag.com/receivers/58/index3.html
Try using the "stereo" function instead of surround sound.
If that doesn't work, try hooking the speakers up to the "B" outputs and select speaker "B" to make sure you didn't fry the outputs on "A", accidentally grounding the pos/neg terminals at the rear of the receiver.
You are sure your "mute" button is off, right? ;)
Dumb question, but did you try turning it up? At what volume is it "quiet"? The 484 is a fairly low model, so it may be that it just doesn't have enough power for what you are asking it to do.
