Hi - For quite some time, I have been running an integrated stereo amp mainly to play vinyl records. I am a vinyl junky, and play records a few hours each day. My last amp, a Marantz 1060, had to be repaired, and again is not working after a year of heavy use. I primarily listen in my living room, but also have a set of outdoor speakers and will often play both sets of speakers. Both sets of speakers are properly wired with good "monster" brand speaker wire. Somebody told me that since my "ohms" are different on my indoor & outdoor speakers it could be causing problems with the amp. My indoor speakers are 4 ohm KEF Tower speakers and sound great. My outdoor speakers are Infinity and sound pretty good too. However, I just looked and the Infinity outdoor speakers are 8 ohm... Could having both 4 ohm and 8 ohm speakers running simultaneously be creating a problem??? I just ordered a used amp online - an Onkyo TX-8511. It is a simple 2 channel amp with less than 0.08% thd, and had good reviews, and I found a good deal so I bought it to replace my Marantz (which I probably still will have repaired). One feature on the amp says it has a "switch" to switch between 4 ohm and 8 ohm. Should I set the switch to 4 ohm or 8 ohm on this Onkyo amp? Also, am I creating a problem by having 8 ohm speakers outdoors that could be easily fixed by having 4 ohm outdoor speakers? I don't mind buying replacement 4 ohm outdoor speakers (to match with the 4 ohm indoor speakers) if that is what is creating a problem. I do not really want to put 8 ohm speakers indoors (because I love the sound of my KEF speakers). I guess I don't understand what "ohm" means when it comes to running 2 sets of speakers. Any help would be greatly appreciated. Thanks so much!
