<font color='#000000'>The short answer is no. You need to find a way to route those wires. Go under your floor or over the ceiling or under the carpet with flat wire. Here is a way I wired a friends house. Go to home depot and get some of the paintable grade wood that fits in the corners that is about 2 inches wide and has angles cut on the sides. I forget what they call it. It will leave a empty space behind it when you put in the corner and between the wall and ceiling. Route your wires behind it and then paint it to match your walls. Cheap and looks good.</font>
