Yup, same brand and you can adjust output if there is any DB difference...having said that, it sounds like you are weighted toward HT vs music. Just my preference, but I prefer the Bi-Polar design of the RS series for HT and a direct radiator bookshelf unit for music....ideal position is on side walls about 6' high and just behind your listening area...I cant do that and mine on rear walls which would be the 2nd choice recommendation by most mfg.
