Do power cords make a difference
  • Thread starter Thread starter Rich0372
Rich0372
21
0
0
54
Ct
I have a dedicated 20amp outlet for my equipment will changing power cords on my amps make a difference my amp is earthquake cinenova 5 it has a 20amp breaker right on the amp Rich
It shouldn't make a difference unless the power cord that you're currently using isn't heavy duty enough. If those amps are capable of drawing 20A from the wall, then you'd better have a 12ga or 10ga power cord on them. Similarly, you should be running a 10ga or 8ga line to that outlet to minimize resistive loss.
However, if you've got proper gauges of cables, then no, a power cable will not make a difference, and it certianly won't make a miraculous improvement.
