I need help.........I have 8 pairs of speakers in the ceiling throughout my home. I have all speaker wires returned into one location. I wired all 16 speaker wires into a 8 zone speaker box. How do I get maximum power? The speaker box is running through an old Aiwa stereo and sounds OK. When all 16 sxteen are running at once, the sound weakens slightly, but overall it was satisfactory. I bought an audio receiver of Ebay used, thinking I would get more power, and all I got was less power, and a receiver with an "overload" feature that shuts down the receiver when the music is turned up. At least the little Aiwa system let the volume crank, the used Pioneer receiver shuts down when turned up. Obviously from my description you can tell that I am a novice in this field, so I need layman terms. Do I buy an amp? What kind of wattage will pump 8 pairs of speakers? What kind of things should be looking for? thanks
PS the used Pioneer receiver I purchased, made in 1999 says: 115W + 115W, 1kHz, THD, 1%, 8ohms....continuous average power output is 100W per, at 8 ohms from 40 Hz to 20,000Hz....(dont know what this means but it may mean something).......
PSS I have all 16 speakers running into a 8 zone switch box, the switch box is then running into a receiver. What do I buy to power the entire house if needed?
thanks......
