I think you would be served best with a control amp, perhaps a preamp/processing type such as the Sony TA-E9000ES. You will need to buy one off of ebay since these have not been made for awhile. All of your source components can plug into this unit like turntable, computer, CD player, DVD player, etc. And, at some later date you can add speakers and additional power amps for surround sound. With a control amp you can also integrate a passive sub into your system as the control amp will properly adjust crossover from mains to sub. Of course a digital pre/pro allows for music sourced from computer without the need of an external dac. All you will need, if the pre/pro does not have a USB input is a USB to S/PDIF converter. In addition to functions like source selection and volume the control amp will also accommodate recording from one source component to another which has a recording capability such as a CD recorder, reel to reel recorder, cassette deck, or DAT recorder. Tone controls have been largely replaced these days by digital sound-fields. The TA-E9000 has a plethora of these tone controls are not easily accessed. I do not miss tone controls. Finally, there are some digital pre/pros out-there which have a lot of video processing capability and the latest movie codex but these amps are very expensive and can become obsolete quickly. I prefer to get the latest movie codex and video processing from the BluRay player. It seems a more economical route to the latest and greatest.
