Do I need a low-pass filter / crossover?
AudioDan
Need some advice- powering and outdoor subwoofer (Near IGS12) with an Audiosource ad2002. My source is a sonos connect. My question is that neither the sonos or the Audiosource amp has a low pass filter/crossover. So three questions-
1- do I need one at all?
2- If so, passive or active?
3- can you recommend an inexpensive brand/unit?
What are the main speakers?
If you want to play the music loud and the main speakers are small, yes- use a high pass crossover.
If you don't want your subwoofer to intrude into the upper bass region, use a low pass crossover.
You don't lose signal level with an active crossover.
Here's a low priced active crossover- I have used a couple of their small mixers and they work well.
https://www.parts-express.com/rolls-sx45-stereo-two-way-mini-crossover-w-sub-output--245-1184?utm_source=google&utm_medium=cpc&utm_campaign=pla&gclid=EAIaIQobChMIm9H-p5Sg4gIVx_fjBx0jdwwHEAQYAiABEgLAOvD_BwE
ski2xblack
ski2xblack
That sub inherently band limits the output due to it's isobaric loading, but even so, the product page does suggest a shallow slope hpf. No hpf frequency cutoff is specified.
Need? perhaps not, but without the hpf you'll be more prone to hear mid-bass and lower midrange content, such as male vocals, emanating from the rose bushes (or wherever you have that sub placed/buried).
Active is the better approach, performed in an amp w/ dsp capability, and also able to drive the 70v distributed setup. (You may want to further describe your setup, as 70v is more a commercial application, which folks here, like me, are less familiar with.) Alternately, since you only need a shallow slope hpf, you could simply use an f-mod line level hpf in front of your Audiosource amp (these are available at Parts Express, very cheap).
THIS is what the manufacturer sells, but there are equivalent amps available from Crown, QSC, etc. that may provide the same functions for a better price. Of course you already have an amplifier, so going this route would be far more costly than trying an f-mod.
