Now see, that makes a difference. The LSis are pretty current hungry. They can run on lower power, but they like as much as you can throw at them. I think the 606 might be pushing it with that center. I have driven LSis with mid level receivers and it works if you don't have a large room and don't need to crank it up, but as mentioned, if you want to push it or have a larger room, it might not work out. The risk being damage to the tweeters from clipping (distortion) as those tweeters are known to be sensitive to it. I don;t think it will put you into protect mode, because damage will more likely occur to the speaker before the receiver has an issue.
I agree that the term "high current" is more of a gimmick, because it ususally doesn't translate into anything meaningful in the real world, but the idea that a big transformer that can produce a lot of current is a good thing.
