I don't think it does. As long as the cheap cable is capable of conducting a signal between the components.
If you are not convinced then why not buy both and have a someone help you with a little blind test? Have them power down the equipment and randomly swap the cable a few times and see if you can hear any difference? Then return the expensive cable.
