Good4it
Do DACs work so we can hear a difference?
And the sources you're concerned about?Yep it's a Yamaha RX A1050.
With a digital source but no DAC you can't hear anything....the digital needs conversion to analog so you can amplify the signal for your speakers (amps and speakers are analog).What would be the sound without the DAC? Would I be able to hear the difference?
In this case your answer makes no sense whatsoever. If you have a digital source you need a DAC so you can convert it to something useful. DACs in general are obviously overrated audiophoolery.I'll must say no as a general statement. Could they? In a worse case scenario, yes
I took it as an external dac FWIWIn this case your answer makes no sense whatsoever. If you have a digital source you need a DAC so you can convert it to something useful. DACs in general are obviously overrated audiophoolery.
LOL....I took it to mean without regard to sourceI took it as an external dac FWIW
Just read the titleLOL....I took it to mean without regard to source![]()
