Hi Bill,
I have my front sub in an unconventional set up but it seems to work quite well. Eldon at Mapleshade audio helped me with this. He’s pretty knowledgeable at meshing old and new equipment together. Check out his web site:
http://www.mapleshaderecords.com/index.php
I have older subs that do not have true LFE inputs. So I use the speaker level inputs on the subs. My front speakers are large. My receiver has a main speaker A/B switch. So I run speaker cables to my front main speakers off the A terminals. Then I run a speaker cable off the B terminals to my front sub. I set the sub cut off to pick up where the main speakers give out on LFE. That way all the low freq. are covered. I set the BD player to no sub and large front main speakers. I do the same in the receiver. So now the front main speakers get the full signal and the sub gets the full signal. So I adjust the sub to pick up the low frequencies that the front mains can’t do. So I don’t even use the LFE analog out on the BD player. It is mixed in and the sub then pulls it out.
Now, admittedly, this is kind of a retarded set up but it seems to work well and I get plenty of LFE. I did it this way so my sub was active when I listen to 2 channel music. Otherwise it’s only active in 5.1. Also, I can set the sub crossover and volume anywhere I want - the control is better in the sub than my old receiver.
I have an identical sub on my rear surround speakers. So I run a speaker cable to the rear sub then speaker cable out of the sub to the little satellite rear speakers. That works well too.
All my LFE are seamless and transition great from front to back. I can set the subs to rock the house or provide subtle complementary LFE.
My equipment spans 3 decades – from my front main speakers being made in the 1970’s to my new DMP-BD55. I have tried to mesh it all together the best I can. I’m really not into throwing away perfectly good high end equipment if I can figure out a way to make it work.
Does this make any sense?
