mbaylor
Has anyone ever made a Y splitter before. I'm looking for some tips and procedures. Thanks.
Y splitter for WHAT? For what purpose? If you're talking about RCA, you can buy cheap ones for a few dollars, so I don't see why you would waste time making one.
mbaylor
I am thinking about adding another sub, so I would actually need 2 RCA Ys.
I guess it wouldn't make a whole lot of sense to mess with making them. I would need to split at the receiver and then split the cable again at the sub to fill both inputs. That sound about right?
mbaylor
My Cadence sub has 2 inputs. A L and R, and the manual says to use a Y splitter to split the signal into both inputs.
mbaylor
Alrighty, well that makes it easy then. This was just an idea I was toying with, so if I get another sub, then I will definitely take you up on your offer.
Thanks for the replies.
F
fergusonv
I don't own a Cadence but I have read many posts regarding the auto on/off and that it pretty much has to have a Y to work properly.
My VTF-2 did also, though it wouldn't go to "sleep" too often. You can also adjust the receiver's sub level up slightly and turn down the sub's gain so the sub sees a little more incoming voltage.
My VTF-2 was also a v1, with the older amp. My guess is the new amps probably don't have this problem. I noticed the issue seemed to be a somewhat common question with the older versions on HSU's forums when it first did it to me. Using the Y solved the problem.
