Hello everyone,
Im currently just finishing up renovations on my basement room, 23'x12'. It has been converted almost into a 'dancehall', including DJ lights, smoke machine, mixing board, computer 'station', etc...
When starting the renovations I purchased a small sized, powered floor monitor. It has a built-in EQ, Bullet style horn + tweeter, and 12" 'woofer'. Im still a little confused on it, (Peavey 112PM Floor Monitor). The site says it is a 75W system at 4 Ohms. The unit itself has a 300W notice on it... I think this is because the amp might be at 8Ohms? Or, I might be lost,
I guess this part is beside the point.
Anyways, I am very eager to add more sound to the room before I start bringing in guests... and have been looking at the option of building my own Loudspeaker.
One of the better materials I've heard of using for building speakers is baltic birch(I know Mackie uses these). I have 40 acres with many birch trees as material, although im unsure of the type of birch(white wood though, and not oily/sap-filled). I know the type of material used for the box effects the sound or 'knock' of it with the low frequencies. Having a fully equiped shop at my disposal, im inclined to build my own enclosure.
I still have a little difficulty understanding amp selection... for example, an amp with a description of
2 x 495 watts at 8 ohms , would either mean it would drive two
two-way speakers at (half) that 495w each, or it might drive both a tweeter and woofer in one box? Im not sure if the 2 indicates two channel, which would mean it could run stereo, or what?
The amp selection, I have understood, should have an output power higher than, or double that of the continuous power rating of the loudspeaker. Is this truth? Also, how do I know an amp will not peak higher than the speaker's rated peak? + Is the damping factor commonly listed on amps?
As for the drivers, etc... I would like to use a single, yet powerful tweeter, (with a large/broad shaped horn), and either likely two 12" woofers, or 2-5 10" woofers. Mackie suggests such designs provide 'tighter base response, greater power handling, and far more impact". Is this truth? Also, I am inclined to make a taller speaker box, standing about 4' tall, thus dual 12's or 15's would be possible/suitable.
In my situation I will only be using one speaker, operating it as a 'mono' output on my mixing board. I assume this will affect my amp selection?
Now, component wise, im not sure if there is a best place to look. I know I can get some from peavey, or a few other websites online, but im wondering if there is a better source? For electronics connections within the speaker... I need the drivers themselves, as well as a crossover? Or two? Im a little confused as to how they work/what they do. Would my input sound connect to the crossover, then to the amp, then the speakers? Or, Into the amp, crossover, then speakers?
And I guess I forgot one last thing. Venting the box for the woofers. I understand the suggested vent depth is 1/2 the depth of the box? Should the vent be carpeted?(A friend has an amazing subwoofer with a monster, 3 side perimiter carpeted vent in his car). And I have heard a box(for a woofer anyways), should be 0.8 x 1.0 x 1.2 times the size of the woofer? (those are 'ratios'). I would guess the first number to be depth, front to back, and other two as width and height, in that order? Should this LF section be physically 'seperated/divided' from the top HF section?
Sorry, my post is overwhelming, but, any help/tips/directions are much appreciated!
Thank-you for reading/replying!
Chris
