A ported enclosure is perfectly capable of producing distortion free bass, and because of the significantly reduced excursion at lower frequencies, the non-linear distortion of the driver will actually be reduced using a ported system. The term 'fast' in reference to bass is an oxymoron. How are the slowest cycling frequencies be 'fast'? 40 Hz is 40 Hz. If it's faster than 40 Hz, it's no longer 40 Hz!
It's all about frequency response! I can take a parametric equalizer, make two measurements(one of a sealed target response and one of the ported system), then apply a transfer function using the parametric equalizer and make a ported enclosure sound exactly like the sealed enclosure -- except the ported enclosure will have a greater SPL/dynamic ability.
Of course, it's easier for the general person to just make a sealed box and have it sound 'fast', I suppose, as compared to applying a transfer function as I suggest above.
-Chris
