The first and second choices will probably be the best for sound quality as they have very low inductance figures and should be quite accurate.)
I fail to see the sense in using Le as a determing factor of 'quality' for a subwoofer. There exist too many variables.
For example, let's take an Infinity Kappa Perfect 12.1 subwoofer. It has an Le of over 3 mH. Relatively high. This driver measures superbly, and better than most, in terms of non-linear distortion. In fact, this
passive driver exceeds in many cases, the non-linear distortion of even highly regarded premium products such as the Velodyne DD 12 servo-feedback controlled subwoofer system.
The Peerless XLS you linked is another good example. It has excellent performance, as verified by Linkwitz, and as such, he chose this driver to use in his Thor subwoofer system.
Consider the JL Audio W7 drivers. These have relative high inductance, according to people on forums that have apparently measured this parameter. Yet, this is an extraordinary high quality driver series with exceptionally low distortion.
-Chris
