Been doing a great deal of reading ( this forum ) and research and I'm this sounds like a pretty good idea. I have had some experience with Eclipse subs back in my car audio days and I do know these will rock
taken from a post by WmAx
"I offer very specific advice, and a multitude of options based on the capability of the person. I can suggest very high quality solutions that involve only buying pre-made/pre-finished sealed cabinets and the user only has to cut a hole for the driver and/or amplifier and connect the wires. No skill at all is required for this. I do not point people to other websites for advice, and I personally make sure that the user knows all of the variables involved if they actually want to do the project. But so far, no one in this thread has actually asked about anything even remotely specific. But since you asked..... here is a no skill required 'DIY' project that will give you higher SPL and lower distortion, than any of the product recommended from commercial vendors so far except maybe the 15" slot ported AV123 option, but I would wager the distortion will be much higher on the AV123 as compared to the following solution:
For $650-$700, one can build a superb sealed 12" subwoofer that will radically outperform most commercial products costing several times as much. For the non-skilled person, I recommend at this price, the Eclipse SW8200 12" driver(it has more linear displacement than most 15" drivers), which is an extraordinary quality device designed by TC Sounds. It has 3x the linear excursion(as verified in 3rd party Klippel analysis) of a normal very high quality 12" driver. Use the 3 cubic foot Dayton Audio sealed pre-fab cabinet, it comes finished in textured black paint. Use the O Audio 500 watt BASH amplifier. It has just enough power and the needed parametric EQ band to get the desired smooth response in this cabinet with this woofer. The amplifier is very high quality, and even made in North America(Canada), and has been measured/verified by 3rd party to be a quality amplification device. Actual output power into 4 Ohm load, continuous, is 430 watts.
If the person won't even cut a hole, then they can take the cabinet, driver and amp down to any car audio shop and they will cut the holes and install the parts for less then 50 dollars."
Driver: $190+shipping
Cabinet: $190+shipping
Amp: $230+shipping
-Chris
__________________
Dedicated to improving the real[quantifiable] parameters of sound reproduction.
