i finally got the parameters for the sub, they are as follows...
RE: 2.8 per voice coil, Z; 4 ohms p.v.c. Le (mH) 1.8, Fs: (Hz) 30, Qms: 4.70, Qes: 0.44, Qts: 0.40, Vas (L) 18, Sd (cm^2): 300, Xmax (m) 29.0, Pmax (W): 1600
its a 10'' sub, but it has the XBLtwo motor structure and is a suprisingly musical sub with good extension (in my 96 land rover) being able to use this as an indoor ht/music sub would be incredible,
