Ok, my first DIY home theater project. I decided I needed speaker stands for a set of bookshelves I have and have been shopping around the past few days. What I've found is everything is made up of primarily the same things and they range in prices from $40 to $200. Well I decided I think I can make something probably just about as good as the $200 set for about the price of the $40 dollar ones. Heres what I've started with:
1/2" MDF that I've had sitting in the garage for awhile. Will be used for lower base doubled up to make a 1" thick lower panel. For the top panel I'm not sure whether I'm going to stick with just a 1/2" thick sheet or double it up as well, I'll see how stable it is farther into the construction project. For the shaft I am using 3" PVC Piping, heavy duty stuff, which I will later fill with sand, figure I can get about 40 to 50 lbs in the cylinder which should make the stand very stable. To attach the PVC pipe to the upper and lower bases I found couplings that attatch that the PVC slides and have a 2" shoulder to give added stability and have a lip on them allowing them to be bolted to the bases. All bolts will be counter sunk to leave level surfaces. Not quite sure how I'm going to paint these yet, I'm thinking of going black on the MDF and silver on the shafts. I'll post some pics during the process, just started tonight so I'm curious to see how long the project will take.
