thanks for the suggestions guys.
mudcat, the chrome techflex is running the entire length of each seperate wire acting as an emi shield. do you think this is still overkill? if i could drop that without significant change in signal quality, i will. what do you think? it is the most expensive purchase for this project. oh and i did plan on using heat shrink. there's plenty at work, along with oscopes, multimeters, and megger line testers! it's good to have free access to stuff.
duff, i love those cobalt cable banana connectors. if i can drop the chrome techflex, i'll replace my connectors with those. do you get good connectivity with them?
