DIY Outdoor Subwoofer Question!!
timoteo
timoteo
So i just put a pair of Yamaha NS-AW350 outdoor speakers on my patio & now have an excuse to build my first subwoofer. Im going to keep the enclosure sealed due to ease of design plus better for being outside. I live on CA so we dont really experience the seasons but still...Since this is a 100% music 2.1 setup i think sealed will be perfect, nice & tight :)
Im going to build some sort of small bench to sit on & mount the sub hidden underneath. My question to all of you is the size/number of drivers to use. Here are three configurations im considering:
1. One 12"
2. Two 10"
Or
3. Three 8"
I already have an Earthquake mono amp that is rated at 280-4ohm & 160-8ohm. Im thinking about getting the drivers from PartsExpress. The sub line is the low priced Dayton DVC Series.
So please, Your Thoughts??!!
annunaki
annunaki
Moderator
Interesting concept here. I would find some drivers that will be impervious to water and high heat that can also do so in a down firing configuration. Not an easy set of objectives to achieve.
The Dayton DVC, if I am thinking of the correct drivers, use a coated paper/pulp cone. This is not a good choice in an outdoor subwoofer in my opinion.
I would look for a poly cone/rubber surround or anodized & coated aluminum cone/rubber surround woofer.
Depending upon placement, you will get little to no reinforcement (transfer function gain) outdoors so sealed may not be the best choice here. The sub's anechoic f6 - f10 is about all you are going to perceive depending upon output level.
Enclosure material will need to be well thought out here too. I would recommend a 13 ply, void free, marine grade, Baltic Birch. This stuff is NOT cheap. I would also use PL premium as your adhesive here for bonding your panels. This will hold up better under harsh conditions long term. I also recommend sealing the wood inside & outside the enclosure to prevent swelling of any sort.
timoteo
timoteo
Thank you annunaki for your response. You are very right about needing the right materials for outdoor conditions. Good thing though is that it will be under a large patio cover away from direct sunlight/elements. The more ive researched the more im thinking of doing an aluminum driver with a passive radiator. However im worried that type of design is hard to dial in right. So maybe a simpler ported is the way to go.
I do plan though to coat the whole inside & outside of the enclosure with a weatherproof spray that is used on the undercarraiges of trucks to protect from moisture etc.
So do you think a dual 8" driver ported configuration would give nice punch for outdoors or a single 10" ported would be better?!
Thanks again!!
annunaki
annunaki
Moderator
Thanks again!!
A dual 8" configuration is about equal to a single 11" woofer in terms of surface area, and a single 10" is slightly less than that (obviously). I would go with the most surface area you can afford here. Space allowing, a 12" would work better than either one. Remember that if using a passive radiator it must remain vertical. The front of the cone cannot point up or down.
If you go vented, you will want to place a screen over the vent to prevent critters and insects from attempting to make a home in there. The undercoating is a good idea since it should seal quite well.
Let me know when you think you may have found a driver choice and I can help you model an ideal enclosure.
Jeff R.
You may want to consider checking into Marine Grade Subwoofers, they will hold up in the outside environment the best. I have a 10" MB Quart in my boat that I regularly hose down with water, it has no issues and good output....
timoteo
timoteo
Thanks for the tip aboit the PR needing to be vertical, i did not know that. Using a marine grade sub had crossed my mind. But since there are a lot of good choices for a cheaper HT sub i figured that replacing it every few years wouldnt bug me since my price is range is under $100 or so.
Thank you annunaki for the offer to help with the design of the enclosure! When i find a driver & get closer i will ask for your help because thats where ill need it. I have the tools & experience to do the hands on part but am still learning about correct enclosure calculations. I downloaded an app that was supposed to help but all it did was recommend their brand of enclosure to buy & not the dimensions to build.
Im thinking 2 efficient/decent Xmax 8" drivers will fit my wants well!
annunaki
annunaki
Moderator
This may be a start to look at when considering marine grade drivers: JL Marine woofer
I have not modeled it yet but it is one option out there.
timoteo
timoteo
Thanks ill look into that one. If its in my price range it seams like a viable option. Maybe worth spending a bit more so as not to have to replace every few years.
timoteo
timoteo
Hey Annunaki i have a question. You mentioned that if i build a sub with a passive radiator that the radiator itself needs to be mounted vertically. However i was reading an article on Sunfires new SDS line of subs & in the description it said that their active driver is front facing & the passive is downfiring!
If its true what you said, why would a reputable company like Sunfire build a sub with this configuration?
Im curious because i like the design they use but not if having the radiator facing down is going to ruin or limit its output or sound quality....thoughts?
annunaki
annunaki
Moderator
Well it is always a little different when one can custom tool a part specific to an application. ;)
I am sure in that case they have a passive with a taut suspension that does not sag or the amount of sag on the passive has been factored into the design.
When a manufacturer has complete control over all components used in the design possibilities could be endless.
