dkane360
dkane360
I'm planning on getting into the DIY scene, and I had a few basic woodworking questions. For tools I'm planning on getting a circular saw and a jigsaw. Anything else I should get? I might pick up a dremel too if you guys think its necessary. I also need wood glue (any specific type?) and clamps as well. Am I on the right track? Anyone have some advice for a first time speaker builder? I'll probably be building the Tritrix TL.
Thanks!
EDIT: Would a router and a circle jig be easier than freehanding with a jigsaw?
dkane360
dkane360
I've already seen that video and seen that thread. Nothing goes into detail about actually cutting the pieces. I just want to make sure that I have everything I'm going to need before I start, and that I do it right. I don't want the precut kit either, which is all the video talks about.
jliedeka
jliedeka
You definitely want a router and circle jig. Most drivers work best counter-sunk. The circular saw will be essential. The saber saw is nice to have but you probably won't use it as much. You could get by with a coping saw and a bigger hand saw for miscellaneous cuts.
Jim
dkane360
dkane360
So I bought the MDF board, had a hell of a time getting it home, then spent a few hours getting all the measurements right. I fit almost everything on 1 board, but it wouldve been a perfect fit had I not modified my plans. I added a few inches to the bottom to give the speakers a little more height and a place to put the crossovers. I'll post pictures tomorrow when I start cutting.
L
Loren42
A table saw is really the right tool for straight cuts. The circular saw can be used with a metal guide.
Both are very dangerous. A neighbor watched a coworker bleed to death after severing his femoral artery in his leg before EMS could get there.
You can find plenty of woodworking magazines and books at a bookstore. Many of the things that work for cabinets and furniture still applies to loudspeakers.
lsiberian
lsiberian
I use a Bosch cs10 circular saw with an Emerson straight edge and a Forrest Woodworker 1 blade. I use a Black & Decker Workmate 225 for my work surface and when possible I use the gap in between as a cut channel.
If I were buying a saw today I'd buy the Makita 5007.
For a router I use the Bosch 1617 with the plunge base for every operation.
I have a Jasper Jig(love it), Bosch flush trim bit(hate it), a Holbren straight bit(amazing bit made by whiteside), and a Freud diablo spiral upcut bit.
You'll also need a drill, and various clamps.
For clamps I prefer the Home Depot variety for their handles.
Though I have the Lowes variety too. I also use corner clamps to line up boards.
For glue I use Titebond. Cleanup is synch with a wet rag.
Whatever you do don't cheap out on bits or blades. Sharper blades are safer, last longer and get the job done.
lsiberian
lsiberian
A table saw is really the right tool for straight cuts..
Doing sheet goods on a table saw requires some skill IMO. I'd suggest starting with the circular saw since it's easier to setup. The hidden costs will eat you alive in this hobby so be aware that tools, wood, glue, clamps, blades and bits cost lots of money. Count the cost before hand including labor. I've grown to love this hobby, but if you don't like getting cuts then do something else. I've been cut by the wood more times than the tools.:eek:
Also count the safety cost. If your job involves significant computer work(engineer) then be overly safe and overly cautious. Losing a finger can be devastating.
Never ever cheap out on tools, blades or bits. Bad tools can kill. Dremels aren't made to do serious woodworking projects safely so drop that idea.
